a z22se head im playing with
ive got a couple of z22se heads so time to play with them :)
the strip down ready for porting and skimming
all out
the inlet side valve seals were shafted the rubber has gone hard
it needs a good skim its looking sorry for its self
exhaust ports are gunged up with carbon and the seats are pitted
new valve guides at some point
big step in the casting line to be removed :)
more soon
the tools i use for changing the valve guides these and a hammer and 2 blocks of wood @IDI AMIN
6mm to get them moving
3mm to push them thru push out from top to bottom then to refit bottom to top
the 3mm is almost the same size as the guide 10mm but once in to the alloy the knurling gets trapped
some modifications shortened the 6mm and ground the knurling off the 3mm
6mm now just pops out 5mm
all the inlet guides were ether to high or to low 10.4mm or 12mm ive now reset them all to the spec 11.2 -.11.4mm :)
#6
I had to use the handle end of my punch to knock it in as i did not have the correct size of punch , but it still done the job and to remove it was the same method except the punch i had available was maybe only covering 3/4 of the guide to push it through the guide hole once the guide was flush with the head .
i know i followed the correct height specs that you posted on my thread which are also in the haynes manual . If i ever do a guide again i will have to buy correct size for doing the work, the set i had was from machine mart they were different sizes but even the largest head did not completely cover the diameter of the guide.
How is it possible that all the valve guides were the incorrect height on this head . Is it just all the new guides were put in willy nilly without the person following proper specs
my set is a draper set like this
http://www.tooled-up.com/product/draper-5-piece-200mm-parallel-pin-punch-set/14117/
at some point its probably had bent valves and then had the inlet side valve guides replaced but were just tapped in and not to the exact measurement
im thinking about knocking them all out and replacing them as there not expensive for a set of guides
its now dropped of at the machine shop for cleaning and skimming
i took the new +1 valves with me to see what they thought about fitting them to my head
they drop right in to a stock head lol
just need the seat cutting back a little
had a bit more time on it today
weight saving lol
cleared out to the seat
bottom matched
modded the diy flap wheel to stop the end digging in
lost more sanding to do
I'm trying to follow exactly what you're trying to do but can't get my finger on it. I see you've cleaned the head and renewed the valve guides, but why are you coloring the inlet ports (or hoe do ypu call them?) blue? What are you exacly trying to do whit the head?
