My bonnet cable seem to have snapped and i cannot open the bonnet, i was told the following:
"remove the o/s/f indicator this can be done by putting a thin screw driver between the bonnet and wing to push the indicator release tab down. once the indicator is out of the way you can see the bonnet catch behind the headlamp use a torch to locate where the cable should be and pull the latch towards you. it should take you about 10 mins to do this"
Please can anyone tell me what the o/s/f/ indicator is so i can try and see if i can remove it ?
