Is this the Turbo size discs? I would also like to have bigger discs but can't be bothered to change the calipers as I would have to take it to a garage :roll:
Yeah you use same calipers and no bleeding involved, just by caution remove the top off the brake fluid reservoir , so the fluid can easily come back up when you push the pistons back in the caliper!.
