Resource icon
Reference Documentation 2007 L61 2.2 Bolt Torque Specs
2007 L61 2.2 Bolt Torque Specs (version 1.0) - 2007 L61 2.2 Bolt Torque Specs
A/C Compressor to Block Bolt
20 N·m
15 lb ft
Balance Shaft Adjustable Chain Guide Bolt
15 N·m
11 lb ft
Balance Shaft Bearing Carrier to Block Bolt
10 N·m
89 lb in
Balance Shaft Fixed Chain Guide Bolt
15 N·m
11 lb ft
Balance Shaft Sprocket Bolt
50 N·m
37 lb ft
Block Heater Bolt
10 N·m
89 lb in
Cam Cover to Cylinder Head Bolt
10 N·m
89 lb in
Cam Cover to Ground Cable Bolt
10 N·m
89 lb in
Cam Cover to Ground Cable Stud
10 N·m
89 lb in
Camshaft Cap Bolt
10 N·m
89 lb in
Camshaft Sprocket...
