2 products I use
Drakey
Firstly, for a quick shine, be it at work or at the manic Drakey household....CarPlans Spray on Shine.
Easy to use and not bad results.
Then from an old friend where I used to work....Chauffeur`s Edge.
Recommended to him by a chap whom he met showing his TVR.
Doesn`t dust up on removal and doesn`t mark plastics etc should you get a bit carried away on application.
Not the best pics as I was a bit tight for space.....may take some more later....if it stays clean long enough!!!!!
