2.4 sc build
So after a false start this LE5 2.4 bottom end is going SC with a Saab head :)
craddle and sump cleaned out
Brand new Saab head ready for some porting
it can either have a plastic z22yh or standard z22se cam cover fitted, so standard coilpack works
a box of new parts from the Saab head
they charge import duty on the shipping, so probably twice as much as a sc :eek:
Currently waiting on parts from the usa, so not much happening with the build.
probably worth stripping off the junk not required, makes shipping cheaper. The vvt head is worthless, I had one laying about for ages and it eventually went to the tip.
exhaust ports opened up and head fully rebuilt
New saab valves - sodium filled, thus better suited for SC than z22se valves
z22se cams, new saab roller rockers, new hydraulic lifters, new valve springs, new valve stem oil seals, new retainers and new collets
Saab head has been modified to accept a z22se cam cover, thus standard z22se coilpack fits
I don't have any issues with my Saab cam cover, but I do have the LSJ pcv pipework.
Using the z22se cam cover means a standard coilpack can be used, so that is now my preferred option. Plus I also purchased a small milling machine which makes it much easier to do.
Build time :D
I weighed the pistons and rods, by swapping rods / pistons / gudgen pins around I got them all within 0.5 grams
gapped the rings and fitted the first rod / piston
all in
oil jets and brand new genuine bearings
polished journals crank goes in
making sure the oil jets don't hit anything
sump all nice and clean
craddle bolted down
sump on and balancer delete installed
brand new genuine timing chain sets
head about to get bolted on, plus balancer chain kit and brand new genuine water pump fitted
cam chain installed
brand new genuine oil pump gasket
TTV flywheel fitted
clutch aligned
external trigger wheel for the z22se ECU fitted, new clutch slave cylinder is in the bag - just incase you were wondering what it was :)
and the 2.4 SC engine is finally finished :D
