On the Vectra B, the automatic transmission ECU is located in the front passenger footwell (for RHD models), I assume you have LHD.
To access it, prise out the retaining clips and remove the undercover from the passenger side of the facia. Remove the glovebox from the facia to gain access to the ECU.
Then, release the retaining clip and disconnect the wiring connector from the ECU. Release the mounting bracket from the body and remove the ECU.
It will have a two letter code on it and if it needs replacing it will require one with the same code but you will then need to have it paired to the main ECU via TECH2.
Hope this may help you.
