lockie2002
Hi have just bought a 2001 plate astra sri, it has 93,000 miles on clock
The previous owner has just fitted new timing chain, balancing chain, and head gasket!
Under hard acceleration it seems to puff out smoke and if been stood then started back up there seems to be a smell of burn't oil!
Could this be the valve stem oil seals? and is this a common fault with the z22se engine?
cheers
cheers
