yeah i know the feeling going to have to have a clean out soon and get rid of the extra partsyou've been busy again with your car! my pile of parts is getting ever larger and running out of storage space, no time to fit anything as to busy fixing cousins first car (corsa c z12xe) new chain done, now got uncles L200 head gasket to do. I need 8 day weeks!
you need the vxr carriers and the vxr callipers ,vxr discs 322mm and vxr hoses but i think i might get away with the hoses need to look its also a different banjo bolt size but CS sell a vxr hose kit that comes with themCarl, do you need the carriers from the VXR or do the 308's work?
thanksGreat updates again. I have the VXR setup on my Astra. Once warm, they're superb.
Are you going to install the Original tmap sensor from the LSJ engine? I'm about to do the same. If you're looking for a connector... the lambdas from lots of Vauxhalls and Opels have the same one
If he does need them @PowR Remap I have just brought these (I'm guessing they are the same for the vec and Astra) http://bit.ly/1b3unrg
and to think, VX wanted almost £150 to replace the split CV boot on the VXR @ MOT time.had some fun today
took the passenger side wheel off to have a look at the alarm siren again!
only to find the inner drive shaft gator split not sure how long its been open but it was still full of grease and not much rust
local car parts called 2 on shelf £13 bargain
stripped all the parts out the way to get the shaft out oops forgot to drain the gear box oil lol but a good excuse to change the oil
its out
after cutting the split gator off with scissors i found the clip
after releasing the clip with a super large screwdriver the joint dropped off
new boot on and put the new grease in the joint
tried to find my side cutters to close the clips up but no joy ended up modding a pair of old mole grips
View attachment 43940 View attachment 43942
went over the seal face with a scotch pad
i then took the opertuaty to fit the front eibach spring to the shock
heres my diy spring clamps
and fitted with grease on the top bearing
all back in and ready to roll well apart from the gearbox oil that will have to wait till the morning
found a new fuel filter and clips in the batcave so they went on to
View attachment 43948View attachment 43947
must remember to look at the alarm tomorrow
thanks
well its a z20let 2.5 tmap CS told me they can now map for it but i will be using an external screen for the ntc probe to keep an eye on the iat not that i have to worry about iat drove 70 mile giving it beans when i stopped the charger was stone cold
http://www.ebay.co.uk/itm/Digital-L...pt=UK_Kitchen_Accessories&hash=item25687fe3df
i have a 2 connectors in my tool bag one maf and one lambda have to look which one fits
will be selling the 308 ones once the vxr callipers are on and working@evocarlos are you still requiring the 308 caliper carriers Carl? I need some now......
vec b and astra g same part there the same caliper on the front Ate 57/25 have a look hereAFAIK the carriers are different on the astras and vectras.....
Only need carriers though, I already have drilled & grooved 308's and Pagid pads waiting to go on ;-)
tbh i cant say i have really noticed it get up to 85-90 the stays there but the water in my charge cooler system aint that hot all down to the thermal gasket no heat transfer from the head to the inletAh ok. that's probably the same one then. How is your rad holding up? I noticed since I have the big radiator for the cc-system, the coolant temps of the regular system go up when I get off the freeway and drive into town. Probably because the intercooler is blocking the main rad. How is that on yours?
because there painted ? lolWould rather have yours
