i poped up to the scrappy to get the 3rd bolt for the washer bottle and got some steering wheel controls as i broke a plastic button on mine
just waiting on the pump and relay to arrive now then its mot time friday morning
think i may put the new bits on the front tomorrow if its nice and not windy as hell like today
here a how to change the LED's in the radio controls on the steering wheel
remove the controls from the steering wheel
from the rear of the controls prise the tabs in that hold the covers in place do the top and bottom then the middle last (dont lose the springs)
then you should be left with this ive marked the + and - on the pic
to remove the old leds you will need to add some solder to the pads with a soldering iron use an iron thats no more than 18w any more would damage the tracks on the pcb
the trick to remove the LED's once you have the extra solder is to swap between the the to pads quickly it should come off on the iron when its just right
im going with bright white LED's there 1206 footprint (+and - of the leds are marked in the pic but the minus is marked on the led with a green dot highlighted by the yellow arrow)
ive got a tin of flux that comes in handy i dip the leds in the flux this helps solder the led to the pcb and helps hold it in place while messing
there on (theres and error in the pic the led to the far left is the wrong way round but i fixed it now)
and a test with the multi meter just to show there right and working
its then just a case of refitting the covers middle one 1st then either top or bottom then refit to the car
oh unrelated but i thought this was cool to
