D-F-A
I had an engine fitted to replace my lovely but worn out 2.2. The replacement had done approx 78,000 at time of install. Since the car has come out of the garage she has not run properly at all. At under 2,00 revs she behaves and also when cold, however once warmed up she behaves as though there is a fuel/mixture/air problem. The car shows no error when on diagnostics other than a reading from a sensor near the air box which reads -40c. We've unplugged that and it made no difference. The garage have no idea and the owners a friend so we're struggling. Can anyone here point me in the right direction. My knowledge of cars is at the Cortina Mk1 level. Thanks in anticipation....Regards Rob
P.s the ancilleries were all from the existing car if that helps. New coil packs were also fitted
